6260 isolation chromecast
1 Topic6250 and Chromecast
Chromecast ist only working on the slow side of my router, not the 5g portion. If I read the chromecast instructions correctly, then I should put the route into "AP isolation : off". The manual refers to "isolation", but does not match up with the admin screens, ie. There is no reference to "isolation". Anybody has an idea what to do? Oh, yes, I did update the router microcode. Thanks you 'allSolved
