99%
1 TopicRN214 hangs at 99% booting after update to 6.7.4 (upnphttpd, rddclient failed, dba import failed)
After updating from 6.6.1 to 6.7.4 my RN214 hangs at 98% (first time) and now at 99% (with "upnphttpd.service" message). - I see "ReadyNAS Admin Page is offline" in browser. - Raidar shows storage with "management service is offline" status. - Diagnostics shows just "Disk 3 has 1 Current Pending Sectors, Disk 3 has 1 Uncorrectable Sectors". - All windows shares are acceptable - LUNs doesn't work (i have VMWare virtual machine with attached iSCSI disk to system iSCSI disk, and that system stucks at bios screen). - Reboot doesn't help. - Reinstall OS doesn't help. - Storage has been purchased more than 90 days ago, so there is no complimentary technical support for now. - And, finally, i have no data backup, so i can't do factory reset (of course, i can copy all files from windows shares, but content of iSCSI-disks is much more important for me). Things I see in logs http.log Jun 05 12:28:25 LONDON apache_access[2301]: 192.168.10.139 "GET /admin/ HTTP/1.1" 200 Jun 05 12:28:27 LONDON apache2[2309]: [error] [client 192.168.10.139] Connect rddclient failed, referer: https://192.168.10.7/admin/ Jun 05 12:28:27 LONDON apache_access[2301]: 192.168.10.139 "POST /dbbroker HTTP/1.1" 200 Jun 05 12:28:30 LONDON apache2[2422]: [error] [client 192.168.10.139] Connect rddclient failed, referer: https://192.168.10.7/admin/ initrd.log [2017/06/02 19:19:39 UTC] Updated from ReadyNASOS 6.6.1 (ReadyNASOS) to 6.7.4 (ReadyNASOS). [2017/06/05 09:09:34 UTC] Updated from ReadyNASOS 6.7.4 (ReadyNASOS) to 6.7.4 (ReadyNASOS). mem_info.log MemTotal: 2065488 kB MemFree: 1453256 kB MemAvailable: 1876636 kB readynasd.log Jun 05 12:28:24 LONDON readynasd[18815]: Error rndb_import() ==> rc=3 Jun 05 12:28:24 LONDON readynasd[18815]: dba import failed Jun 05 12:28:25 LONDON readynasd[18871]: readynasd log started Jun 05 12:28:25 LONDON readynasd[18871]: readynasd started. (restarted=0) smdb.log [2017/06/05 12:19:19.881135, 2] ../source3/auth/auth.c:305(auth_check_ntlm_password) check_ntlm_password: authentication for user [Anton] -> [Anton] -> [anton] succeeded [2017/06/05 12:20:04.845425, 2] ../source3/auth/auth.c:315(auth_check_ntlm_password) check_ntlm_password: Authentication for user [Administrator] -> [Administrator] FAILED with error NT_STATUS_NO_SUCH_USER system.log Jun 05 12:28:27 LONDON apache_access[2301]: 192.168.10.139 "POST /dbbroker HTTP/1.1" 200 Jun 05 12:28:29 LONDON dbus[2026]: [system] Activating service name='org.opensuse.Snapper' (using servicehelper) Jun 05 12:28:29 LONDON dbus[2026]: [system] Successfully activated service 'org.opensuse.Snapper' Jun 05 12:28:30 LONDON apache2[2422]: [error] [client 192.168.10.139] Connect rddclient failed, referer: https://192.168.10.7/admin/ systemd-journal.log Jun 05 12:28:34 LONDON systemd[1]: Starting ReadyNAS System Daemon... Jun 05 12:28:34 LONDON readynasd[19085]: readynasd log started Jun 05 12:28:34 LONDON readynasd[19085]: readynasd started. (restarted=0) Jun 05 12:28:34 LONDON readynasd[19085]: DB (main) schema version: 23 ==> 23 Jun 05 12:28:34 LONDON readynasd[19085]: DB (queue) schema version: new ==> 0 Jun 05 12:28:35 LONDON readynasd[19085]: rndb_sql_get_scaler_mprintf is called with SQL which has vector output. (ncol=1, nrow=2). Jun 05 12:28:35 LONDON readynasd[19085]: SQL Error for SELECT FROM `group`. Jun 05 12:28:35 LONDON readynasd[19085]: rndb_account_import() ==> 3 (384ms)Solved7KViews0likes10Comments
