AP mode
6 Topicsex8000 nighthawk X6S mesh network via AP mode
I have a Nighthawk X6S EX8000 and would like to know if the mesh WiFi will still work if in AP mode? I have a Nighthawk X4S router and have an Ethernet cable ran to where I have the Nighthawk X6S extender, is there a way to have the mesh WiFi work without having the WiFi extender connect to router via WiFi824Views0likes1CommentCircle Parental Controls Don't Work if in AP Mode?
I was excited to see I could put parental controls on the Orbi, but then after loading Circles app and trying to enable it said it didn't work in AP Mode. As I have a router from my ISP that also provides cable TV I have to use their router in order to see the TV Listings that come in through the Coax connection on the main router. any ideas on how I can resolve this inability to use parental controls? P.S. Orbi works well, but disappointed with the limited features to manage on the unit via Admin - many more on the cheaper FIOS router.Netgear R7000 not letting me login after putting it on AP mode
Hi, I remember first installing the R7000, I was displayed with either AP mode (not sure if that was what it was called) or regular mode. I chose AP mode, as I had slower connections on regular mode. Now that there have been so many updates, I want to update my R700 for security purposes. However, I am unable to do so, as everytime I try 192.168.0.1 or routerlogin.com. I am taken to my modems menu and not my netgear R7000 menu. The modem is a Netgear CG3000-2STAUS (Yes Optus provided modem). I've looked through many articles that have been suggested to me; however, none of them have address my issue. I tried restting both the modem and router, and when I do, all my devices are still connected to the router. Everything is the same and nothing changes when I try to reset. I hope there is an answer out there, tecnical support via telephone has passed, and so has the warranty.Solved954Views0likes11CommentsUsing mac adress filtering in WIFI AP mode
Hi, I just installed the ORBI50 system to my network. As I use an untangle firewill/router, I need the Orbi to act as an access point. I installed the system as access point and that seems to work. For security I wanted to use mac adress filtering as I did in my previous setup (on topo of a WPA password obviously). However I can't find the setting to do this anywhere in AP mode? Can someone help me out with this please? Thanks, DavidGuest isolation in AP mode works on latest firmware...almost (tl;dr IPv4 is OK, IPv6 not so much)
The good: Things work like you'd expect - you can reach the Internet but nothing on the local network except DHCP and DNS. The bad: If your network has IPv6, it completely bypasses isolation. Netgear, thank you for putting the effort in to get this right for IPv4, but please don't forget it's increasingly an IPv6 world out there. Please add proper isolation for IPv6 in the same manner you already are for IPv4. RodneyWhy ever use Orbi AP mode?
Hello. I have been generally pleased with my Orbi on AP mode - good wireless coverage etc. But I would like to be able to isolate certain devices on the guest network, and it seems not possible in AP mode. Why not just switch back to router mode? My Orbi router is currently plugged into a cable modem/router (with wifi disabled) from RCN (my cable provider). I suppose I would have 2 LANs, but if the only thing on the cable modem's LAN is the Orbi router, what problems will I have? Thank you!
