APN R7100LG roaming
1 TopicAPN Nighthawk R7100LG which APN with roaming
I am using this router only in my camper with a SIM-card, so using mobile broadband. The SIM-card is from Vodafone, the SIM pin is deacticated and roaming is on. So I am travelling through Europe passing continious different networks. My first question is whether I should enter the APN from my own provider (of the SIM-card) or that of the actual delivering provider through roaming? In case of the 2nd one this would mean that I need to change this with every change of provider. Is there another solution?Solved3.2KViews0likes2Comments
