Advanced Features
46 TopicsAircard 763S MEP Unlock tool for Windows 10
I want to unlock my Aircard 763S but I am having issues downloading and running Aircard Watcher. I have downloaded and started the exe file from http://downloadcenter.netgear.com/en/#searchResults but it will not run on my Windows 10 OS. I can not find that the program has been loaded and installed either. Is there a more up-to-date download file that I should use? Need some help on this as I am stuck. Also, does anyone have the unlock MEP code for the Roger's version of this? Thanks a lot. ErikAircard 763S MEP Unlock tool
Help! Trying to unlock the aircard (763S) but the link provided by Fido (service provider) is to a Sierra wireless website and does not work. I have installed the drivers, have an unlock code, but I haven't been prompted to enter it. Using a Mac - OS X El Capitan 10.11.13. HELP ME! Thanks.SolvedAC810s LTE category configuration
Hello, I'm about to buy one of these mobile routers AC810s. On technical details page I see two revisions(?) with different LTE cat 9 vs 11 configurations. http://www.netgear.com/service-providers/products/mobile/mobile-hotspots/AC810S.aspx#tab-techspecs Can someone answer me if these are different hardware revisions and I need to look for particular one, or is it simply some software configuration? BR ZbyszekAirCard 810S Mobile Hotspot Carrier Aggregation is not showing all bands
Hello, simply question :) When my device AirCard 810S cat. 9 is in range of LTE+ it means, that is connected minimum to 2 or 3 bands (frequencies), right? I check Download and Upload and I can see, that's true - connection is definitely speeding up whithin LTE+. BUT when I checked Status Details, the device always shows me only one band. So, I cannot check, what frequencies my device is currently aggregating. So, my question: What to do, to see on the AC810S screen all bands, which are currently aggregating by my device been in range of LTE+ ? Thank you for the answer.AC790 and an USB to Ethernet adapter
What chipset does AC790 feature? With what USB-to-ethernet adapter will it automatically work, i.e. what model will be out-of-the-box supported by AC790's kernel? Netgear's own cradle uses such a mechanism, so clearly this is possible. On Windows AC790 connects over USB using RNDIS protocol, so USB tethering is also possible on Linux using similar mechanics, but what about stand alone usb-to-ethernet adapters? Thanks for helping me out.6.2KViews0likes3CommentsMBR1515 External Antennas
Help, I am moving to a remote area, my Verizon' phone works good there ,However my MBR1515 Mobile Broadband does not, can i connect a external antenna,s up to this unit , i see there are two antenna,s on the back are they both for broadband tx/rx?? or is one for wi/fi ? if anyone knows what type of antenna and connector i need?I will order one or two as required?, I am not planning to use my wi/fi portion of this netgear device only the internet ,connected to wired PC,s any ideas or help would be such a welcome every one i have asked suggested everything but the correct out side antenna , HELP ,Thank you in advance,EagerbeckyNeed port forwarding help on 6100D
I have a 6100D gateway with a public IP address (Sprint). I've successfully set port forwarding for four ports on one internal IP address (192.168.1.20). I've tried to forward two additional ports on a SECOND internal IP address (192.168.1.28). I'm permitted to add the IP address and ports, but in a short time, the IP address is CHANGED by the router to the first IP address. I don't know why the second IP address is not retained. The port is retained. I'm using DHCP with a DHCP pool of 10-50. I'm using internal IP addresses of 20 and 28. I set the IP address in the reservation area with their respective MAC address. What am I doing wrong? Can someone help? BTW, same results with Edge and IE browsers.Stop hotspot from powering up
I have an AirCard 779S (Sprint) – NETGEAR® Fuse Mobile Hotspot. I was wondering if it's possible to prevent the device from powering up when it's already off and USB cable is plugged in? You might ask why would you want that. Well, I'm usually at home when I charge the device and I don't need it broadcasting its SSID. I have a home network for that. My current workaround is to plug it in, wait for it to boot, and power it off. The thing is, this takes time and effort to remember. Is there an option for this that I'm not seeing?SolvedMonitor traffic on periodic billing (not monthly)
Hello, Recently my ISP (a major mobile operator in Europe) decided to change the billing period from "monthly" (on a fixed month day) to "every 4 weeks" (usually the period is shorter than a month so in the end we have 13 billing periods per year) therefore it seems impossible to keep track of the traffic usage leveraging the standard Hotspot monitoring tool. Is any update to the firmware planned or any workaround available (besides looking directly to data provided by the IPS)? Thanks in advance.AirCard® 340U (Telus) USB Modem
Can I use AirCard 340U (Telus) USB Modem in combination with DGN2200M modem router???? I want use the DGN2200M for ADSL and, if the ADSL fails, i want use a 4G connection with the AirCard 340U. Is it possible?? Is the AirCard 340U compatible with DGN2200M??? Thanks to all.
