Airplane Mode
1 TopicA6210 Windows 10 Airplane Mode
Hey, I was using my A6210 with Genie 10.0.0.34 on a Windows 10 PC when the device started disconnecting repeatedly within minutes, then seconds. I uninstalled Genie, got the 10.0.0.35 install, and then found Airplane mode was stuck ON. I went through the solutions on the internet, short of the registry edit procedure. Nothing worked. I deinstalled/reinstalled a few times and now the WiFi is working again, with airplane mode still ON?! However, Genie does not recognize that the A6210 is installed. Device Manager shows "802.11ac Wireless Lan Card" with driver provider Netgear, 4/21/2015, v5.1.22.0. Any clues to getting Genie working? As I said, I have connectivity through this adapter. Thanks!5.1KViews0likes4Comments
