Apps
32 TopicsAircard 763S MEP Unlock tool for Windows 10
I want to unlock my Aircard 763S but I am having issues downloading and running Aircard Watcher. I have downloaded and started the exe file from http://downloadcenter.netgear.com/en/#searchResults but it will not run on my Windows 10 OS. I can not find that the program has been loaded and installed either. Is there a more up-to-date download file that I should use? Need some help on this as I am stuck. Also, does anyone have the unlock MEP code for the Roger's version of this? Thanks a lot. ErikCan not send sms with Netgear Nighthawk m6 6500
Does the device for 1000€ lack such a basic function that was in all previous m models? I can't send SMS either from the router, or from the application, or from the web panel. And without this function, the router simply turns into garbage, since my operator obliges me to send SMS every 10GB. Surprisingly, a year ago I asked to add the Auto send SMS function, and now it turns out that this function is either hidden or absent.Mobile app not recognising my MR1100
Lots of issues here. Firstly when I download the mobile app to allow me to configure my router it says it does not recognise the product. Therefore I cannot move on Second, when I install the Sim, the router tells me I need to configure my APN, then all of a sudden this disappears and I am connected We went to France and I could not access the router anywhere so could not configure it for use in Europe I am on the verge of binning the thing I am so frustratedReconnect to Device MR60 and T-Mobile
I recently moved away from Comcast/Xfinity Internet and hooked up with T-Mobile Home Internet. It works great. My old system includes two MR60 units mesh system, which also works great. When I plug the MR60 into the T-Mobile (Nokia) gateway, the MR60 gets immediate access. So, the home Internet system/access works great. The problem comes in when I try to use my Netgear Nighthawk MR60 app on my iPhone. Under the Comcast account, the app worked great. Now, I keep getting an error message to reconnect (see screenshots). Is there an issue with T-Mobile home internet access and the MR60 mesh system? Any recommendations? Thank you!Nighthawk M5 MR5100-1Z1MES useless In Middle East
Good day NETGEAR COMMUNITY ! , First of all, We are in big trouble because a lot of people In Middle East They didn't get the new update : Model: MR5100-1Z1MES Firmware Version : NTGX55_12.04.12.01 GUI Version: MR5100-1Z1MES_04.02.197.00 HW Version: 1.1 _________________________________________________________________ Most of people stuck on version : 10.12.13.0 & 10.28.02.00 Which is very old version and you cannot change band option's from the router ! You shall to change It from 192.168.1.1 ! Also, when you tried to check for updates It's give you UP TO DATE ! _________________________________________________________________ Is it difficult for a large and leading company in the field of routers like Netgear to Push an OTA update 12.04.12.01 to all owners of the MR5100-1Z1MES model ? By the way .... The vendor not cooperate at all In Middle EastSolvedNo Carrier Aggregation icon on LED Display or Apps or WebApps
Hi.. I cannot find any icon or status show my modem is doing carrier aggregation. On LCD, it just dispaly 4G all the time. Same also in WebApp and Android Apps.. no icon or status show carrier aggregation or 4G+. It very hard to know my modem get 4G+. Sometimes I need to do speedtest to find best spot to park my modem.. and it waste my 4G data. The only way to know is by using telnet AT command. But need a pc connection Most android phone have 4G+ or LTE-A. This features is simple, but very usefull information for users. It is easy for users to locate/find the best spot to park the modem, since M1 is portable. As we know.. 4G+ vs 4G give different speed result. Nowdays .. most cat 6 or above lte modem show 4G+ like Huawei, TP-Link. Hopefully Netgear team can enable 4G+ status on LCD/webapps/apps. Thank you. Device : Netgear MR1100 FW: NTG9X50C_12.06.02.00How to install firmware my router
hi i have router netgear mr100-100eus when download update frimware unplug charge from my sune but now router is no work when power on the router restart every 1 minut i when serch from the netgaer i found frimware mr100-100eus type tgz and when enter page router and chosse the frimware he need anthor type not tgzNighthawk M1 No option to turn off wifi when ethernet is active
I always plug AP mode router to my modem using ethernet port. My router already have dual band wifi with high dbi antenna. So each time i connect my router, I have to disable internal builtin wifi in my modem to avoid clash channel. To disable both 5Ghz and 2.4 Ghz wifi, i need to use netgear webapp feature to access my modem. There is no option to turn off wifi in netgear android app. So each time i have to access web before I can connect my AP router. then if i want to disconnect, I to access web again to enable first before disconnect. I have to use browser to access netgear web. Better if netgear can provide option to turn automatic turn off wifi when ethernet port is active, then modem will turn on again wifi when ethernet port not active or disconnected. Sometimes if i turn on wifi in menu (in webapp) , my 5Ghz SSID also change to default with _5G at the back.. and i have to go to other menu to set again. There also option by set wifi standby, and wifi will turn off after no one connected.. but i have to check every device to make sure they connect to my AP router SSID, not the modem. Device : Netgear MR1100 FW: NTG9X50C_12.06.02.00
