Band Steering
1 TopicNighthawk X8 R8500 Band Steering
Hello everyone. I'm looking to buy this amazing router as it gets available in Spain, so I have read every review available, and I found one thing that could be very frustrating. There's no option to set the same SSID on 2,4Ghz and 5Ghz band... So you will have to set separate SSID. I think this is a huge disadvantage, becouse, maybe the router has no band steering implemented? Becouse the Smart Connect feature, just works between 5Ghz Bands, but what about device that support 2,4Ghz and 5Ghz? It should provide band steering between bands using the same SSID, as this will reduce congestion on 2,4Ghz and force all 5Ghz enable clients to use this band. I had also both setups in the past, one with different SSID and one with the same, and the same SSID is much way better, also as the people that does not have IT knowledge, they choose a band aleatory, and if they choose the 2,4Ghz band with a 5Ghz capable devide, they're congesting the band with no reason. With just one SSID, there's no option for wrong decission. Is there a reason for that? All the other manufacturer routers with the same Broadcom chip, has band steering, so I think there should be no incompatibility issues. Is there any option to set the same SSID? Maybe Smart connect could work with all the three bands, instead of just the 5Ghz bands. Thank you. Regards.Solved10KViews0likes6Comments
