Blocks on Display
1 TopicReadyNas NV+ Post New Power Supply Boot Issue
Recently my ReadNAS NV+ stopped working after almost 8 years of running. It would not power on. After reading all of these forums, I concluded that my power supply most be dead. I ordered a new one on Amazon that match the same Voltage, Freq, etc. of the current PS. Install went smooth no issues. I decided to boot it up with no HDDs to verify it worked. It turned on, however, the display screen was lit and display "blocks". The blue glow around the power button did not turn on. I tried turing off the system and it would not. I tried with a quick power button press and also held it for a number of seconds 10+, 20+. No luck. I read that I should be able to see the NAS on the frontpage and I could not. I decided to try it with the HDDs installed. Same issues. The fan is working everything seems to be ok. Thoughts? Thanks!1.6KViews0likes8Comments
