Blu-Ray
2 TopicsSamsung Blu-ray player says the HTTP port is disabled
I am trying to connect my wired Samsung Blu-ray player to the internet and I keep getting the message that the HTTP port is disabled. I have tried assigning its own IP address and also entering the router settings manually into the player. Nothing works, so I’m looking for suggestions.Solved88KViews0likes11CommentsArchive to USB Attached Blu-Ray Burner
All - Now we have 128GB write-once blu-ray discs and burners in the market (BDXL, BD-R 3.0) I am thinking this could be a good long term archive solution for the ReadyNAS. But I've search the forum and elsewhere and not seen anyone reporting success archiving content from a ReadyNAS to USB 3.0 attached blu-ray burner. Anyone care to share their experience? What drivers on the ReadyNAS required to do the burning? Any limitations? Is Shell Access required or is there a plug-in for a user friendly UI? What burner hardware worked for you?6.8KViews0likes7Comments
