Broadcast Name
1 TopicCan't disable 60GHz 802.11ad Broadcast Name from being transmitted
Model: Netgear R9000 / AD7200 Nighthawk X10 Router The 60Ghz LED is lit on the router, and under the "Advanced Wireless Settings (60GHz 802.11ad)", the "Enable Wireless Router Radio" is unchecked, but the "Broadcast Name" is still transmitting. All of the other bands are unchecked and aren’t transmitting, so why is this the only one? I've tried every possible configuration in the router setup, but nothing works. Any idea on how to turn it off?Solved4.3KViews0likes3Comments
