Cant Connect to Internet
1 TopicConnected to Extender, but no Internet
Hi All I just purchased a Wifi Extender due to poor signal for my Android Box in another room as well as to help increase the signal strength across the house. I want to use the ethernet plug from the extender directly to the android box as I've heard that's better than the wifi path. The issue I'm having is that I can get my devices to recognize the extender, and connect to it... however they are not able to connect to the internet. I've tried multiple factory resets, both with setup via ethernet cable/WPS and still am not having any luck. I am able to connect to 192.168.1.250 when I have the EXT network selected, however no other pages will load. The Extender I have is N300 / Model EX2700 The router I have is Linksys EA4500 Any help will be appriciated! This is driving me slowly insane :)Solved425KViews0likes17Comments
