Channel Bandwidth
1 TopicWAC104 Unable to Control WiFI Channel BandWidth
I setup 4 WAC104 as Acces Points, and there are no settings available to limit channel Bandwidth in 2.4 and 5GHz spectrums. There is a compatibility setting which appears to give no control over BandWidth. The shopping Center is very congested and I would like to force SSID "VillageLife" to 20MHz (See attached Images). This should be a setting to make it more friendly in congested areas. Apple devices do not use 40MHz, only 20MHz. Am I missing something? I contacted Tech Support and they claim there is no setting to limit Bandwidth, and told me to post it here. Most WiFi AP units I have dealt with allow you to limit bandwidth, so I'm surprised to see there is no bandwidth setting, and therefore hard to recommend to other clients (we like the 4 LAN ports SWITCH, allowing us to hardwire local computers to Ethernet and not WiFi).23KViews1like2Comments
