Create Folder
1 TopicCannot create new folder on R7800 ReadyShare using Win 10 Explorer
For some reason I am unable to create a new folder with a unique name, or rename an existing file or folder on any ReadyShare network share using windows exporer. I can copy existing files and folders from any of my PCs to the share, but if I try to create a new folder or rename an existing file or folder in explorer, i get an error message. If I try to create a new folder with a unique name, say "Temp," I get the following error message: If I hit cancel then a new folder appears on the share as "New Folder." If I try to rename the "New Folder" to some other name, I get the same error message. I I try to rename an existing folder on the share, say change "\\ReadyShare\USB_Storage\Backups" to "Old Backups," I get a similar error message: Like I said, I have no problems copying existing files from my PCs to a share using windows explorer or creating new files using other apps, e.g. Word, Excel, etc. I can also delete existing files from the share using explorer. I have tried this with several different USB storage devices and I get the same behavior. For some reason it seems like the name changing process in explorer cannot find the file/folder that is being renamed. I have been working around this issue by creating new folders on my PC and then dragging them to the share but this seems like a strange way to have to do it! I am using an R7800 Nighthawk Router with the latest firmware V1.0.2.12. Any suggestions would be appreciated! Thanks!Solved15KViews2likes35Comments
