Device Limits
2 TopicsRange Extender with NAT ???
I'm in a location that has horrible internet service (1mb/s) and the only realistic choice is using a mobile hotspot (tablet). It offers unlimited 30-60mb/s. Unfortunately, it supports only 8 devices, and will not hotspot via USB or ethernet... only WIFI. I need a device to increase the WIFI to 24 or more devices. Essentially, I need a regular wireless/wired Router, but with a WIFI WAN/internet input. (instead of ethernet). or Another possibility would be a WIFI extender with built NAT and a DHCP server to assign IP addresses to the connected devices (like in a router). It would present only one IP address to the hotspot regardless of the number of devices attached. The problem is that regular WIFI extenders simply pass through the IP addresses of all the connected devices to the hosting hotspot... to make things worse, the extender itself becomes another connected device. I can't believe that I'm the only one in the world who needs to connect more than 8 devices to their home hotspot. Suggestions???WPA Key limitations ORBI wifi router
Is the number of active simultaneously connected devices connected to an Orbi router limited by the number of WPA keys it can support? Are the 50 streaming devices assumed to be streaming with encrypted links? Is the 50 limit per Orbi unit? Where are the device limits documented? Thank you, Chris
