Device View
1 TopicDevice view not working! Java not supported anymore
Hi, I can't re-enable a port on my GS108Tv2 because the Device View tab requires Java and Java applets are not supported by any browser anymore (I'm on a Mac, and Safari, Chrome, and Firefox all no longer support Java applets). What should I do? Is there an updated version of the software that I can use? Thanks!Solved9.3KViews0likes2Comments
