Disks migration
1 TopicReadynas duo v1 migration
Hello, The NIC in my old Readynas duo v1 w 2x2TB disks gone bad. I got another Readynas duo v1 device, that came with one 2tb disk in it. I need to make the new Duo work with thedisks from my old one. If I just remove the disk that the new Duo has come with from it, and insert both disks from my old Duo, will that work and the data on old disks be intact? Or should I do something special, like' say, OS reinstall with my old disks? thank you for your helpSolved3.3KViews0likes1Comment
