Double NAT
2 TopicsNeed help with XR500 double NAT on Xbox One
Hello, I installed my XR500 today, before I was using an AC1900 which had open NAT, however I now have double NAT at Strict. What questions should I ask my internet service provider and what settings should I use? I already went to settings>WAN Setup>NAT Filtering>Open. My new router connects to a PoE Adaptor. I managed to get the AC1900 to Open NAT but that was years ago and I forgot the process I took to get there.Solved17KViews0likes12CommentsDouble NAT -- R70000 -- Google Fiber
I have a Google Fiber box and have a R7000 set up downstream (the R7000 has better range and I'm able to setup OPEN DNS). When I set this up it created a double NAT situation because the Google Fiber Network Box does not have a bridge mode. In the last couple of weeks I installed a wifi security camera at my home (car got broken into recently) but have been having network problems with the camera where it will go offline or won't capture the video well. Based on some google searches it looks like security cameras don't do well with double NAT. Is there anything I can do to help this situation> The best explanation on double NAT I've found is at http://www.practicallynetworked.com/networking/fixing_double_nat.htm. At the bottom it gives some suggestions on port forwarding or DMZ. Will these work in my case? Other suggestions?Solved12KViews0likes4Comments
