EX6400
3 TopicsAirprint printer not reachable fromv EX6400 extender network
Hi there I have a wifi network with a D7000 modem/router and a EX6400 extender, with a HP Officejet 5740 printer connected via ethernet cable to the D7000 and a number of Apple devices (iPhones, iPad) connected via wifi. If an iPhone is connected to the router wifi I am able to print via Apple Airprint, but when it's connected to repeater wifi (SSID ..._EXT), the same printer appears as unavailable. I read on other posts that Apple Airprint services, like others (audio video streaming , IPTV), use IP multicast (or mDNS or Bonjour) packets, which seem to be not re-transmitted by the extender. Any ideas?901Views0likes1CommentStampante Airprint non raggiungibile da rete extender EX6400
Ho una rete wi-fi con modem/router D7000 e extender D6400, con una stampante HP Officejet 5740. Se il mio iPhone è collegato alla rete wifi del router principale riesco a stampare con Apple Airprint, mentre se è collegato alla rete del repeater (SSID ..._EXT), non vedo in Airprint la stampante. Il repeater è compatibile con Airprint? Ci sono settaggi particolari? Grazie Enrico5.8KViews0likes4CommentsConnecting Both EX6400 & EX3700 Extender to Verizon Router -
Hi Guys; I have a Verizon Fios Home network. 3quick questions. 1) Can I have an EX3700 and EX6400 extender connected to the same Verizon Router? Of course with Unique SSID for each extender.. 2) Does Fast-Lane Technology works when Extender is said to HotSpot? for some odd reason my EX6400 doesn't diplay the option for Fast-Lane Technology when in HotSpot mode only if I set it to Extender mode. 3) Which of your Cable Modem router works well with Verizon Fios? which bring Coax Fiber Optics direcctly into my home. Thanks and Regards;3.4KViews0likes1Comment
