Ethernet reset router
1 TopicI have a R7800 reset router every time for wired connection
I'm not a very tech savvy person, but every time I try to connect to the internet with a Ethernet cord I have to reset my router to Be able to connect to the internet. It works perfectly fine after I reset my router until I use the pc or Xbox again.Solved3.4KViews0likes4Comments
