FVSN problems
1 TopicFVS318N router keeps dropping network connectivity
I have had consistent problems where my router drops all connectivity. This is both for wired and wireless connections. When this happens, I am able to ping the routers IP address but am unable to log into the router. I power cycle the router and it comes back for a couple hours to days but the problems continues to happen. Netgear has sent me a couple router by RMA but they have all experienced the same problem. I have Verizon FIOS. My Verizon router and Linksys routers I have are rock solid. I want to use the Netgear for its VPN functionality. Netgear support has never been ab,e to give me a solution. I am current on the firmware which is . 4.3.3-5. Does anyone have any suggestions as to what may be causing this behavior? ThanksSolved15KViews0likes13Comments
