Fan speed
1 TopicReadynas Ultra 2 - fluctuating fan speed OS 6.6
Hi There. The rpm of the fan in my Ultra 2 is constantly flucuating between ~750 and ~875 every few seconds. I can hear the fan speed up and speed down over and over again. THe voltages and temperatures seen quite steady. The fan is set to quiet, and I'm running os 6.6, although I believe the same behavior was present when running 6.5.2. Do you have any idea, why it is doing that? Below is a screendump of netdata. Thanks in advance, /beack3KViews0likes4Comments
