Fixing the 40 MHz loss
1 TopicIssues with the 2.4 GHZ side of my Netgear WNDR-3400V2
There is an issue as of late when I had the oldest firmware I had 150 MBPS connection when I upgraded to the previously latest firmware it dropped down to 72MBps and now with the current firmware it will not give me more than 72 on one card and the laptop I am using it is a strange speed of 58.2 and does not go above that. When I connect to 5 GHz it gives me more speed. And the problem is I need the full speed in order to use my NAS drive effectivly. I suppose I just better connect an ethernet cable in when I want to use the NAS to get the full speed otherwise I am limited to 58.5-65 Mbps around 6-8MB/s* I am fed up no matter what channle I choose, I cannot get the speed back. This is not a N600 router because of this issue. My Belkin N150 gives me full speed so it is not RF interferance. Anyone have any idea? Or would me installing the OPEN-WRT help me get my speed. This router has 8MB Rom, 64MB Ram and a 500+MHz processor. My LG2 802.11/abgn connects at 108 MBps on the 5Ghz band, my Kindle Fire HD 2013 (On 5Ghz band) connects at 108 MBps, my Nokia Lumia 1020 connects at 72 MBPS, my desktop connects at 72MBps (2.4 GHz band), My HDTVs are uncertian as I do not know on which band they connect, Any idea on what to do to take advantage of the speed this device CLAIMS to do? I need to know if I could go back to an older firmware, or find a WRT system that allows me to agressively set up the 40 MHz. I am saddened that I have to do these things.. Let me know *100 MB/s is 12.5MBps transfer rate in windows dialogSolved
