Genie display
1 TopicWDNR4300v2 One device displays twice in the Network Map
My Genie's network map shows the same device, a TiVo Roamio Pro, twice. In each detail display, only the IP Address varies. One of the addresses matches the one displayed in the Roamio's network settings, the other address doesn't match. Until yesterday, this device was connected to the WDNR4300v2 wirelessly, but now the connection type for both instances is shown as wired even though I have run only one Ethernet cable from the Roamio to the router. I see no way to remove the bogus instance of the device. How can I correct this?Solved
