HP Network Switches
1 TopicJE003A Baseline 24-port 1Gbps PoE Smart Switch
AKA 3Com Baseline Switch 2924-PWR Plus (boot 1.0.0.14 software 01.00.10- latest versions) Netgear ReadyNAS 1100 (RAIDiator 4.1.10 [1.00a147]) Symptom: Uploads run quickly Downloads run very very slowly 300MB takes over an hour. 1,000s of Unrecovered TCP Retransmits in the NIC errors on the NAS Steps: Upgrade the firmware on the switch and the ReadyNAS Replace the network lead Run IOmeter - Read test, does not produce results, performance percentage is less than zero message in dynamo window. Plug into alternate 100Mb switch and file download works ok and read test works. Re connect the 3Com and set both ends of the link to 100Mbit FDX and once again the file download works as does the read test. 300MB takes under a minute to copy. So I am now running my ReadyNAS at 100Mb FDX instead of 1,000Mb. Can anyone suggest a way of getting this to run at the full network speed?
