Hardware Servicing
1 TopicWNDR4500v2 Router Recovery Using UART Serial Converter
For an unknown reason, the WNDR4500v2 Router has stopped working correctly. I am also unable to access settings on 192.168.1.1, routerlogin.net, routerlogin.com, or via NG Genie App (PC). I suspect the firmware has been corrupted. Standard procedure for resetting the router (via reset button) does not correct the problem. Although, evidently from SSID(s) some settings have been reset. However, network ID via LAN suggests some settings have not. In addition, I have also tried the 30/30/30 reset method, without success. Research lead me to a number of tftp solutions (via Netgear support forums). However, both MS tftp and tftp2.exe methods fail with error: No response from server. The router does allocate the correct IP (192.168.1.2) to host (but attempted manual override also). And, the Router does respond to ping on 192.168.1.1. nmap scan reports ports 53, 548, 20005, and 5000 are open. Since the device is way out of warranty and virtually a brick, I am considering trying to resolve the issue via UART Serial Converter after watching the procedure on a TP-Link Router. Can anyone advise me on which USB to UART Converter to use specifically for the WNDR4500v2, and which jumpers on the board I will need to connect Putty on? (J252 already has pins, but I have no issues soldering pins into JP5 or J251 if necessary). Any additional links or information would also be greatly appreciated! Thank you.Solved
