Installation
5152 TopicsMy extender won't connect to my new router
I recently changed internet providers and now my extender won't connect. I factory reset it and used the Nighthawk app to set it up. On my phone it says it's connected, but the extender itself doesn't show it's connecting. I also have an ethernet cable connected from the extender to my desktop. My desktop still isn't connecting to the internet, so I know the extender isn't working. I called support and after TWO hours, they were unsuccessful in helping me. I'm calling back again and I've now been on hold for an HOUR! This is ridiculous. Unhappy is an understatement. Please help.2.1KViews0likes3Commentshow to replace a r7000p-100nas with a rs300
The RS 300 showed up and would like to know if there is a video on how to replace/remove the Netgear Nighthawk AC2300. If there is no video, then can I get some help on what is the best way to get this accomplished. I have 2 hardwired desktops, hardwired laptop, iPhones, iPads and an EPSON & HP ENVY Pro 6544 printers. I am thinking that there is software to be removed from the computers. Thank you280Views0likes1CommentImpossible to install Arlo Go2 camera on Orbi RBK53
The Arlo Go2 camera needs a phone with the Arlo app connected to 2.4GHz. The RBK53 won’t let me choose the network, and the phone always connects to 5GHz. I’m not sure if there’s a way to temporarily disable 5GHz to force the phone onto 2.4GHz for setup. I tried the setup in the Arlo app, but the camera doesn’t chime when scanning the QR code, so I can’t complete the process. The camera worked before, but after the battery ran out and I charged it with a cable, it disappeared from the Arlo app and I’m trying to bring it back. I already have two other Arlo Go2 cameras working fine. Any help on forcing my phone to connect to 2.4GHz would likely let me finish the setup.Does Orbi 54 RBR50 as access point need to be on a wired LAN?
I have 2 Orbi 54 routers and am trying to set up the second one as an Access Point. I already have 2 satellites but I had to move one to be closer to a 4K tv to get good Internet. I followed the instructions (https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point) and set it up for a dynamic IP but when I did, the second router did not give me an option to connect to the router. I tried sync buttons but it didn't work. Does it need to be hard wired to connect as an AP? I really need it wirelessly to get it down a long hall. I also can't log in directly to it via Ethernet because it keeps saying the IP is self assigned and it says Router and DNS server, but gives no IP address to connect to in a browser. Maybe this setup is not possible?SolvedOrbi RBR850
I purchased the RBR850 with 2 satellites. I could not get the install to work with my iPhone, so I used a laptop. I installed the router and was installing the satellites when the solid white light on the router went out. So i powered everything down and plugged it back in, blinking white, then no light. So I hit the reset briefly and it did the same thing. Someone suggested to me that the firmware might be corrupt or need an update. So I held the reset button in for a longer time to restore the router. I started again, got to a point where I could update the firmware, it was going along and then the light went out again. Any ideas before I return this thing. I'd be more confident but I had install issues with the first one that we bought and Netgear gave up. Either i have some kind of bad luck or I don't know whatWi-Fi Adapter - internet speed slowness
Moved a desktop computer, Windows 11 Pro, to a room without wired ethernet. Desktop about 5 years old. Purchased a Wi-Fi Adapter, Nighthawk, to get internet. Installation was easy. Using an internet speed program I get 25Mbps download with the adapter. My laptop in the same spot gets over 150Mbps. The USB adapter is plugged into a v3.0 port (blue). What could be the problem? USB v3.0 are supposed to be much faster. Thanks!Solved1.1KViews0likes3CommentsA7000 Windows Drivers, not the installer
Hey there, Trying to install Windows 11, but it needs a network connection to go. I am nightmarishly aware that the driver page here exists, but that is an installer package that assumes Windows is already installed and running. Extracting the contents of the installer using 7zip does not help; the driver files are encoded into the installer file. I need the actual raw driver files that Windows can recognize so I can get this install going. Any help is appreciated. Thank you.1.4KViews0likes1CommentTwo RBR10 bases in AP mode?
I have an RBR10 AC1200 Orbi base unit in AP mode and two RBS10 satellites. These do a great job covering the office wing of our church. This WiFi network can be accessed, but is faint in the sanctuary half of the church. I’d like to extend the mesh to include the entire complex. There is no LAN connection available in the middle of the complex - only in either wing. I don’t want to daisy-chain satellites over WiFi from the offices to the sanctuary - I’m afraid that would hurt throughput. Can I create another AP from the ethernet LAN in the sanctuary wing and “connect” it to the existing mesh? I don’t believe the RBS10 satellite has an ethernet LAN connector, so couldn’t use another of these as my 2nd AP. Could I take a second RBR10 base, configure it as an AP like the one in the office wing? The two base APs can chat via wired LAN. But would would they play nice and create a cooperative single wide mesh? Note - neither base is working as router, or DHCP host. Just working as AP node.Solved
