Installing WN3000RP using cable
1 TopicWN3000RP Installation using co-axial Cable
My router N900 router is installed in my basement. Signal is too weak to cover the second floor thus I need to install the range extender on the second floor. Placing the extender on the first floor provides unreliable coverage. My house is equipped with co-axial cables whereby wired internet access is supported almost everwhere. How to I place the extender on the second floor, connect it to the router through an exiting co-axial cable then provide wireless connection all over the secound floor using the extender. Is this possible. If yes, what do i need to do?Solved3.3KViews0likes5Comments
