L2TP IPsec
1 TopicFVS336Gv3 - L2TP/IPsec on Windows 10
I am in the process of testing an FVS336Gv3. I have a working site-to-site VPN with a Mikrotik device using PSK, and have another thread at the moment for instruction on how to upload cert/key for the S2S tunnel. I am now in the process of configuring an L2TP/IPsec VPN on the device. I notice there is L2TP configuration options, but did not see anywhere to specify the IPsec settings for the L2TP connection. Additionally, I have searched the forum and found an official Netgear employee post the following link as instructions on setting up the L2TP VPN: https://drive.google.com/file/d/0B4PuVEYxkQ5oMXppNzVnT3lLUEU/view?pli=1 In the document, it says to specifically modify the WIndows registry to disable IPsec (!!!). Is this a limitation of the device? Does it not support L2TP WITH IPsec? Because if so, that's fairly useless as a remote-access ("road warrior") style connection; not only are many of my clients using mobile devices/operating systems other than Windows (OSX and a few Linux), but that is also very insecure. So is it possible to configure L2TP with IPsec? That is a pretty standard, well-supported VPN connection methodology, and you DO advertise the device as being capable of L2TP and IPsec.....Solved30KViews0likes7Comments
