Legacy Nas
1 TopicLast update of PLEX, 1.2.3 fails to install on OS 6.6.0 (RN PRO x86)
Hi all, This will happen when you try to install on os 6.6.0 (x86) Wed Oct 26 2016 1:26:46 Cannot install application plexmediaserver-ros6-binaries_1.2.3.2914-1ff0f18_amd64.deb. Oct 26 01:24:37 xxx-xxx-xxx readynasd[3620]: ResetFailedUnit: GDBus.Error:org.freedesktop.systemd1.NoSuchUnit: Unit fvapp-plexmediaserver.service is not loaded. 1.2.2 installed perfectly... Ideas? No help at PLEX either: Link to Thread on PLEX forums. Short and closed. Wich logs do you need? Could it be right or something else? The thing is that PLEX 1.2.2 works and installed fine. Best regards HansSolved6.6KViews0likes15Comments
