MGMT Service is offline
1 TopicRN3220: Netgear NAS "MGMT Service is offline", looks like Enclosure RAID5 & DB is down too #28163337
Hi, we have an issue with a RN3220 with "VMware lost Access to NAS Storage, Netgear NAS "MGMT Service is offline", looks like Enclosure RAID5 is lost and therefor DB is down too", OS Re-Install did not help - does anyone have other ideas for fixing the issue? ################################################################################################################################ Infos from Logs: [2015/09/21 06:09:51] Updated from ReadyNASOS 6.1.8 () to 6.2.4 (ReadyNASOS) [16/11/06 20:37:45] warning:volume:LOGMSG_VOLUME_USAGE_WARN Volume 'RAID5' usage exceeds 95 % of size (40.0 TB). [16/12/07 12:15:28] event_push.c:169 Cannot start transaction [16/12/07 12:16:12] event_push.c:186 md_event readynasd <xs:update-s resource-type="Volume"> <VolumeEvent EventName="DegradedArray" DevName="md127" SecondDevName="none"/></xs:update-s> 0 0 ==> ec=0 [17/02/26 03:33:51] event_push.c:186 md_event readynasd <xs:update-s resource-type="Volume"> <VolumeEvent EventName="Fail" DevName="md127" SecondDevName="/dev/sdj3"/></xs:update-s> 0 0 ==> ec=0 => Initiated Reboot [17/02/27 15:32:25] event_push.c:186 rnutil readynasd <xs:add-s resource-type="Device"> <CommandName>Reboot</CommandName> => Initiated OS Install [2017/02/28 21:40:54] Updated from ReadyNASOS 6.2.4 (ReadyNASOS) to 6.2.4 (ReadyNASOS). ################################################################################################################################ Errors during Boot Up: [DEPEND] Dependency failed for /RAID5. [DEPEND] Dependency failed for Apps Directory. [DEPEND] Dependency failed for Home Directory. [DEPEND] Dependency failed for Local File Systems. exportfs[2994]: exportfs: Failed to stat /RAID5/Veeam_Replica: No such file or d exportfs[2994]: exportfs: Failed to stat /run/nfs4/RAID5/Veeam_Replica: No such exportfs[2994]: exportfs: Failed to stat /run/nfs4: No such file or directory [FAILED] Failed to start ReadyNAS System Daemon. ################################################################################################################################ readynasd.service loaded activating start ReadyNAS System Daemon start-raids.service loaded active exited MD arrays ################################################################################################################################ root@NAS01:/var/log/readynasd# systemctl status readynasd.service readynasd.service - ReadyNAS System Daemon Loaded: loaded (/lib/systemd/system/readynasd.service; enabled) Active: activating (start) since Fri, 03 Mar 2017 10:53:04 +0100; 44s ago Main PID: 4360 (readynasd) Status: "Importing DB" CGroup: name=systemd:/system/readynasd.service + 4360 /usr/sbin/readynasd -v 3 -t Mar 03 10:53:04 NAS01 readynasd[4360]: readynasd log started Mar 03 10:53:04 NAS01 readynasd[4360]: readynasd started. (restarted=0) Mar 03 10:53:04 NAS01 readynasd[4360]: DB (main) schema version: 18 ==> 18 Mar 03 10:53:04 NAS01 readynasd[4360]: rndb_create() ==> 3 (0ms) Mar 03 10:53:04 NAS01 readynasd[4360]: Error create table (db) Mar 03 10:53:04 NAS01 readynasd[4360]: dba create failed ################################################################################################################################ root@NAS01:/var/log/readynasd# systemctl status start-raids.service start-raids.service - MD arrays Loaded: loaded (/lib/systemd/system/start-raids.service; static) Active: active (exited) since Fri, 03 Mar 2017 09:34:53 +0100; 1h 18min ago Process: 1784 ExecStart=/usr/bin/start_raids (code=exited, status=0/SUCCESS) CGroup: name=systemd:/system/start-raids.service Mar 03 09:34:53 NAS01 start_raids[1784]: mdadm: NOT forcing event count in /dev/sdj3(1) from 1527356 up to 1527369 Mar 03 09:34:53 NAS01 start_raids[1784]: mdadm: You can use --really-force to do that (DANGEROUS) Mar 03 09:34:53 NAS01 start_raids[1784]: mdadm: failed to RUN_ARRAY /dev/md/RAID5-0: Input/output error Mar 03 09:34:53 NAS01 start_raids[1784]: mdadm: Not enough devices to start the array. Warning: Journal has been rotated since unit was started. Log output is incomplete or unavailable. Thanks, Christian3.3KViews0likes2Comments
