Management service offline
3 TopicsManagement Service Is Offline
Hello everyone, I have a readynas2120 v2 with firmware 6.7.3 After the latest update, i can't access to the storage with dashboard. If i use raidar i can see Management Service Is Offline. I tried with Chrome, firefox on 2 different PC (Windows and Linux OS). I have access to the shares/folders/files. No integration with AD Any Idea? Thanks in advance Regards3.6KViews0likes5CommentsReady nas 212 Management service offline
Hi everyone, I'm near to NAS systems and I use this model to backup my two PC little LAN since this january. Nothing special happened till today. I tried to read some similar post here in the kb, but I sense only wth log analisys it's possible to understand what's going on.. Today, after manual reboot, I find the power LED blinks continuosly. No soft or hard poweroff possible, even if after a power cord disconnession the probem is stille there. I acces the files stored the Uranium backup utility I'm usinge to batch the incremental backups is able to do his work but I cannot access the management page to set up automation in power ons and offs. I downloaded all the logs via RAIDar program but in the zip there is a bunch of files and I'm unsure on what to do. Hoping someone could help me in some way. thanks in advance, Davide2.9KViews0likes1CommentReadyNAS Management services offline
I have a ReadyNAS RN312 running OS 6.2.4. A while back, one of the harddrives failed, which I replaced with a new drive. The drives synchronised correctly. A few weeks later, the second one reported errors. I rebooted the NAS to see if it was something spurious. The error went away, according to the admin page. A day later I tried to connect to do some other work on the NAS and the admin page was not available. Symptoms: I type in the url to the NAS and get the login prompt within a second. The webpage shows the progress bar for about a minute and then tells me the admin service is offline or the NAS is busy. If I run Netgear RAIDar, it finds the NAS immediately, but reports that the "Management service is offline". The admin page button opens the same admin url with login prompt, but still fails to reach the admin page. The pages shows both drives with a green tick over each. Does this mean both drives are healthy, or both are installed? I can download the logs but can't find anything particularly helpful, except for these errors: md/raid1:md127: active with 1 out of 2 mirrors md127: detected capacity change from 0 to 1995430559744 kernel: md127: unknown partition table systemd[1]: home.mount: Directory /home to mount over is not empty, mounting anyway. (To see the over-mounted files, please manually mount the underlying file system to a secondary location.) The Diagnostics button returns these results. System Disk 1 has 8 Current Pending Sectors Disk 1 has 8 Uncorrectable Sectors The RAIDar page shows two green ticks. Does this and the errors above conflict? I have done an OS reset but not a Restore factory settings. Is there anything I can do to restore the admin function, or is a factor reset the only route? Please help regards. BCSolved4.9KViews0likes5Comments
