Mobile Routers
438 TopicsSending SMS from MR6450 or MR6500.
There is no option to send SMS with the MR6450 or MR6500 !! I never had a mobile router that did not have that option. For the Netherlands you absolutely need that option to request extra GB on a nearly daily basis. The main internet provider in the Netherlands KPN works with a 10GB daily limit and you can request via SMS additional 2GB every time you need it. So this $1000 router is pretty much useless without the SMS option for use in the Netherlands. Is it in the planning to offer the SMS option in the near future ?? Thanks in advance for any information on this subject.MR6550-100APS & MR6550-100PAS / which ones is the best for 5G bands in Viet Nam (APAC)?
Hello everyone, As mentioned in the title, I really need help about which Netgear models is the best to use for 5G in Viet Nam (a country in Asia Pacific - APAC) ? Mr6550-100PAS or Mr6550-100APS According to this knowledge base link as below https://kb.netgear.com/000065647/Which-countries-can-my-NETGEAR-M6-or-M6-Pro-roam-in The model Mr6550-100Pas will be the best fit … but it’s for American area … To be honest I’m really so confused And based on the specs of Mr6550-100Aps, it should be the one … totally different with the KB above So I really need your advice , any recommendations or suggestions are highly appreciated Thanks so much for taking the time to readNighthawk M6 Pro MR6400 won't run without battery when tethered to computer
Hello, I recently purchased the Nighthawk M6 Pro MR6400 hotspot. Unlike the MR5200 and MR6500, it does not seem to want to power on without the battery connected when tethered to a PC. I checked all of the settings in all three hotspots and they are identical. The USB port is set to charging and tethering. The same exact PC and USB-C port on my PC works for the MR5200 and the MR6500, but will not work for the MR6400. Is there a way to bypass this? I have checked the power settings of the device and they appear to be identical. I am purposefully not installing the battery except for when I will be traveling with the device. Thanks!M6 MR6110 WIFI zzzz icon
Hi, I'm using the AT&T MR6100 and from time to time the icon of the Wifi got a "zzzzz" on it. I mean the Wifi signal is probably "sleeping", and i can't find it with devices. But i'd like to know why the Wifi is sleeping and how can i wake it up ! Nothing about it on user manual. Seems it's not related to global Airplane mode on the router... Seems it's not related to wiring ethernet to the router too... So if someone can help preventing sleeping Wifi, it would be great ! thanks a lot.Unable to save changes to WIFI Network Name on Nighthawk M3 MH3150
I can't save any WiFi changes on my new Nighthawk M3. I have followed the instructions in the manual, but the Apply button is disabled. I've tried on my phone and on a laptop and get the same problem. Device works with the default name and password. Updates have been installed To change the WiFi network name, password, encryption, or channel settings from the web user interface: 1. From the web user interface dashboard, select Settings > General > WiFi Band. The WiFi Band page displays. 2. Click or tap More. Additional settings display. 3. Enter a WiFi Name and WiFi Password. 4. Select an Encryption Type and Channel. Your WiFi client devices must support the encryption type that you select for your mobile hotspot, or they will not be able to connect. 5. Clear or select the Broadcast WiFi Name SSID check box. If you clear the check box, you must manually enter your SSID when connecting your WiFi devices. 6. Click or tap ApplySolvednetgear nighthawk m1 MR1100
Hello a few days ago the message appeared: Keine Verbindung mit diesem Netzwerk möglich (no connection possible to this network) when I tried to connect any device to the MR1100. Any device means: a samsung mobile S23 with Android, a Microsoft surface with windwos 11, an apple IPAD pro with IOS 18. What can I do to find out how to reanimate the MR1100 without access from a computer via WiFi to it. Thanks for Help GorowRV rooftop antennae for MR6550 nighthawk
Hi, We recently looked into getting an RV and are wondering about combination antenna like the Winegard 360deg which has AM/FM, TV, WiFi, and LTE/5G capability which seems to be very popular, but wanted to investigate other options. What have people used with their Nighthawks that they'd recommend? ThanksMR1100 display freezes after starting
Dear Community, the MR1100 always stops during the start-up process and nothing happens after that. The Router has a LTE signal and is basically working, but the default screen is not visible (see the attachment). After the reboot, 1-2 attempts, the router is working fine again and the default screen is visible. Thank you in advance. Regards Dorian631Views0likes0Comments
