Multi-Gig
18 Topics[MS108TUP] - Switching - VLAN and routing
Hello everyone, I've this network configuration: Firewall --> MS108TUP --> Access Point Wifi The firewall and the AP is not a Netgear product. I've a domotic house so I've decided to separate the smart devices from the Main network. So in this case I've created an dedicated AP SSID with VLAN ID 20 only for manage smart devices. My network is also managed by a dedicated firewall device that manage VLAN Interfaces, WAN Interfaces, LAN Interfaces etc etc. Throught this Firewall, manage all the L2/L3 levels, from DHCP (one for every interfaces) to Privacy control, from Captive Portal (for Guests account) to Policy Control rule, ACL, Static route, QoS etc etc. So, I've configured the MS108TUP with several VLAN created in Switching mode (Switching --> VLAN). This is my current VLAN configuration on MS108TUP: MG1 is the Firewall uplink port, instead MG2 is the AP Uplink port. And this is the configuration of the interfaces into my Firewall: In this way, the AP create a SSID with VLAN 20, MG2 take the VLAN 20 and route it on MG1 VLAN 20; the firewall (MG1) take the VLAN 20 on port P2 and create it's own network with it's own dedicated DHCP and Static IPs list. All works good but when, from the firewall, I try to block traffic from/to the same interface/zone, not working. For example, if I try to block the SSH port from the tablet to my Raspberry PI and the tablet and the RPI is in the same interface/zone, the traffic is not blocked (my rule is: from DomoDevicesVLAN to DomoDevicesLAN source "tablet" destination "RPI" any service --> deny ----> this rule must deny the traffic for any service from the tablet to the RPI "using" the same zone but not work). Seems because the packet traffic is directly managed by the MS108TUP. Seems as the request is not passing throught the firewall, but remains at the switch level. For example: 192.168.0.5 --> 192.168.0.6 directly In this way the traffic is bypassing the firewall, because remain into the "switch" level Instead, how I can route the traffic thought the firewall? 192.168.0.5 --> 192.168.0.254 (Firewall interface) --> 192.168.0.6 In this way the traffic must pass into the firewall, and in this way I can have full-control on the packets and I can apply a Policy Control rule. Thank you so much Best Regards, Valerio1.3KViews0likes13CommentsXS724EMv2: UL listed / certified?
Hi. I'm searching for successor >=24 Port 10G-BaseT L2/L2+ Ethernet Switch as the current model XS728T is End-of-life. Netgear offers the XS724EM, which is also End-of-life, and the new XS724EMv2, which seems to be perfect for our use case. But as this is an important requirement for our international business the Switch must be UL listed or certified. Based on the datasheet the obsolete XS724EM is UL listed (UL listed (UL 1950)/cUL IEC 950/EN 60950), but I can't find any UL specification in the datasheet of the new XS724EMv2. So, I want to ask if anyone here can check the name plate on the XS724EMv2 switch if there is any symbol regarding UL or cUL. Thanks in advanceXS512EM ports download speed
I just purchased a new XS512EM switch from Netgear's Amazon store. Updated firmware to 1.0.2.5, created two VLANs. VLAN1 has port1 for management connected to internal 172.16.200.x LAN and VLAN2 has ports 2-12 for external static public IPs 47.181.202.x. No QoS enabled, no speed limit Everything seems to work fine except I don't get symmetrical speeds on VLAN2. The uplink is a 2G/2G Frontier FiOS using their Optical Network Terminal (ONT) FRX523. If I connect a computer directly to the ONT 10G port I get 2G/2G all day long. If I use my old 2.5G unmanaged switch I get 2G/2G all day long on all ports. I opened a case with Netgear and they have never encountered nothing similar. Did I miss something in the configuration process?. A Frontier tech came onsite and checked the ONT and verified 2G/2G speeds today. [root@mail ~]# speedtest Speedtest by Ookla Server: Frontier - Los Angeles, CA (id: 14236) ISP: Frontier Communications Idle Latency: 3.84 ms (jitter: 0.34ms, low: 3.44ms, high: 4.67ms) Download: 1208.43 Mbps (data used: 708.7 MB) 4.16 ms (jitter: 0.39ms, low: 3.48ms, high: 5.39ms) Upload: 2352.98 Mbps (data used: 2.6 GB) 4.78 ms (jitter: 0.30ms, low: 3.07ms, high: 6.02ms) Packet Loss: 0.0% https://www.speedtest.net/result/c/0d419a3a-90ab-4321-b4bc-474756a90ef3Two Active Switches With Redundant Uplink
Hi, I am looking to connect both switches to my Firewalla each on port one. I am also looking to create a LAG between the two switches on the sfp ports. I am using the default vlan to assign ip addresses to the management port of the switches using dhcp. I also have a single vlan 20 for the remaining ports (also assigned via dhcp on different subnet from vlan 1) on the switches. My sfp lag between the two switches is a trunk for vlan 20. What I cannot figure out the correct STP (RSTP or MSTP) settings to prevent the switches from freaking out (rapid light blinking). The switches should know that all vlan 20 are routable without going through the firewalla and are acceptable via the connected LAG. Only the default vlan 1 should get routed via port 1 and any ip not on vlan 20. Also note that all of vlan 20 is on the same subnet. The firewalla also supports tree spanning which is turned on.XS724EM firmware 1.0.2.5 has NO-link issue with Cisco c300/c350 SMB switches at 1G link speed.
XS724EM firmware 1.0.2.5 is NOT fully compatible with Cisco small medium business 1G switches. For example, Cisco C300 SMB Series, C350 SMB Series, etc. To be clear: XS724EM Firmware 1.0.2.5 = Unable to pass any traffic to-from Cisco SMB switches at 1G whatsoever. XS724EM Firmware 1.0.2.0 = Works fine with Cisco SMB switches which ONLY support 100M or 1G links speeds. I had to downgrade XS724EM from 1.0.2.5 firmware, back down to 1.0.2.0 firmware, for it to be able to connect and work again with any of the Cisco SMB-series switches. In the 1.0.2.5 firmware release notes, it says, "A new physical layer driver is supported to improve interoperability." - I believe this to be the problem. as no physical link-layer communication is working using this XS724EM 1.0.2.5 firmware with Cisco C300/350-series SMB switches at 1G speeds. AND, because XS724EM does NOT have any feature to force speed at 1G, this means it is unable to link at all - no traffic passes whatsoever. In my opinion: This newer XS724EM firmware 1.0.2.5 should be pulled from download, reverted to 1.0.2.0, then patched, and finally re-launched again later (when compatibility is tested better). THANK GOODNESS, that NetGear still allows download of prior 1.0.2.0 firmware and lets you downgrade to work with Cisco again. The older NetGear firmware is located here (directly from NetGear): https://www.downloads.netgear.com/files/GDC/XS724EM/XS724EM_V1.0.2.0.zipSolvedXS708T LAG with two 10G Mac ports says switch doesn't support 802.3ad
Simliar to jdmarlow's post here https://community.netgear.com/t5/Plus-and-Smart-Switches-Forum/Cannot-get-LAG-working-on-XS708T/m-p/2181135/highlight/true#M20138 I've been unsuccessful at bonding two 10G ports on a Mac on the XS708T switch. The difference with mine is I do have the two ports bonded on the MAC and LACP is turned on the LAG/switch; howover my Mac says my switch doesn't support 802.3AD Link aggregation. Any guidance or suggestions would be greatly appreciated, ThanksHow to handle: Total Received Packets Not Forwarded
I have an MS510txm switch. At port 10 I have attached a sfp+ module with fibre (from 10GTek) operating at 10GB. The link is connected to another switch witch is connected to PC. The operation from PC over the link is working, but the detailed port statistic shows increasing numbers of "Total Received Packets Not Forwarded". May be the performance over the link is related to this effect? What causes the switch to not forward the packets? Is there a solution for that? On the other ports I dont see this behaviour. Regards WolfgangProSafe XS508M losing connectivity between laptop and router after rebooting router
Hi there, I have a switch ProSafe XS508M and my router and ubuntu server are connected through it. The network interface configuration of the server has two IP address: LAN and WAN ip addresses, so they are two different IP networks. I tried this with different routers: after rebooting the router a couple of times, I loose connection between the server and the router and the only solution I found is to power cycle the switch. I'm not sure how to debug this issue, any idea would be appreciate. Thank you!
