NV+ Transfer RN204
1 TopicTransfer Files From NV+ to RN204-100NES
Hi I'm about to purchase (I think) an RN204-100NES with a single 6TB drive, the intension will be to transfer the files across from the NV+ to the RN204 keeping the NV+ as the backup until I can afford to fit a second disk. I'll then continue to add disks as required. Simple question, what is the fatest an most reliable way to transfer the files, they are both physically connected to the same router? Any advice much appreciated3KViews0likes2Comments
