Network problems
1 Topicnetgear wifi extender wn3000rp - cannot access the main pc from the wifi laptop
I have networked a laptop via wifi to a PC using a HomeHub and the WN3000RP. If I connect the Laptop via this 'Ext' connection I cannot access the PC, but can see it in the network list. If I connect the laptop directly to the HomeHUb and on to the PC (not using the Externder's wifi connection), I can access the PC. The PC can access the Laptop both on the direct HomeHub wifi and via the 'Ext' wifi link. I have tried resetting the Extender, but with no success. As I can access both PC and Laptop via the Homehub/wifi it seems as though the Extender is blocking access to the Laptop from the PC. Any suggestions, please?3.7KViews1like3Comments
