Nighthawk AC1900 R7000
1 TopicHelp - Nighthawk R7000 Speed for WAN and Internal LAN
Hello everyone, I have a small question. I would like to know what are the achieveable speeds of the R7000? For example...When transferring between to LAN devices, I am getting speeds of at max around 580Mb/s...This has nothing to do with the WAN Port because its all LAN computers and devices....But when U am doing this LAN transfering at these speeds I then do lets say a speed test on Speedtest . net the LAN transfer drops significantly and my internet speeds from the WAN Port are slower than normal. Is this normal? I have heard or read somwhere that the R7000 has a MAX speed of about 580Mb/s at the WAN port, but that should not affect the LAN when im doing a speed test. Am I correct? Thanks for the responses in advance. Ill galdly give any more inforrmation that is needed to help...Solved7.1KViews0likes7Comments
