Not booting up
1 TopicWNR3500Lv2 does not switch on
Hi, I was using my Netgear router all this while without any problems. Since about a month or so, I have been using a mobile hotspot at home and hence not been using my cable boradband (and by extension, my Netgear router). Now when I tried using the router, it just doesn't switch on! I tried plugging in to another slot on the switchboard, but that did not help. My cable modem boots up fine, but not my Netgear router! Could you please help out? Also, how do I make sure the problem is in the router and not, for instance in the power plug or chord?Solved
