Not resolved
1 TopicMD5-Signed Certificate Warning with OpenVPN on iOS
As of version 1.2.8 of the OpenVPN app on iOS, OpenVPN issues the following warning: > WARN TLS: received certificate signed with MD5. > Please inform your admin to upgrade to a > stronger algorithm. Support for MD5 will be > dropped at end of Apr 2018 The warning appears as a modal dialog that interrupts use of the device. If the device is unlocked after a short period of time with the VPN connected, there will typically be multiple modal dialogs. This is an extremely frustrating experience. There appears to be no way to disable this warning and nothing router owners can do. A similar issue arose earlier for Android users (https://community.netgear.com/t5/Nighthawk-WiFi-Routers/Netgear-R7000-and-OpenVPN-for-Android-App/m-p/1310857). It is still unresolved at the time of writing. Netgear needs to issue a firmware update that changes the certificate used for OpenVPN.Solved38KViews4likes108Comments
