OS 6.5.0
1 TopicCannot upload apps under OS 6.5.0 on PRO 6
Hi, I'm running LMS 7.8.0 on a legacy PRO 6 using OS 6.5.0. When I installed LMS 7.8.0, I was running OS 6.3.5 and I used Logitech's logitechmediaserver_7.8.0_all.deb together with superpoussin's lms_1.0.8_all.deb Last weekend I wanted to upgrade LMS from 7.8.0 to 7.9.0 using the logitechmediaserver_7.9.0~1472633108_all.deb file which can be downloaded from Logitech's nightly builds. When trying to upload the file, I get error message "Cannot install application D:\....\logitechmediaserver_7.9.0~1472633108_all.deb". Installing the lms_1.0.8_all.deb also generates the cannot install error. Does anyone have any idea why I cannot install Logitech's deb files on OS 6.5.0? I even cannot install the 7.8.0 version anylonger, which worked fine on OS 6.3.5. Many thanks for any help!Solved
