Orbi Wifi
2 TopicsOrbi RBK40 not working with Chromecast Audio
I just set up my Orbi RBK40 system, and configured my Chromecast Audio to connect with the new mesh wifi. It worked great for a day, and then Chromecast Audio lost the connection (got kicked out by the Orbi wifi). I reset the Chromecast Audio and got it connected again, it worked great for several hours, but then lost the connection again. Are there settings that can be changed in Orbi that will allow Chromecast Audio to work with the mesh wifi?Upload speeds very slow on Orbi via Wifi - On ethernet its at 100%- why?
So I've just got a new 200mbps dedicated fibre connection (clean full signal) and am using my Orbi Wifi system. On the Router Speedtest via the Orbi app (the speedtest of the router and the connection directly, a.k.a. not Wifi) the connection on download is 321mbps and upload is around 150mbps, i.e. full capacity. But on Wifi for some reason the download speed is 260-290mbps but the upload only around 25-50mbps. I can't for the love of god figure out why the upload speed is so slow! Can someone please help me? Is there a setting or something that helps the UPLOAD Speeds go to full throttle via Wifi? All my connections are via Cat 7 cables and everything is top grade!Solved
