POE+
1 TopicGS316EP POE is dead
Hello everyone, I got a GS316EP switch with PoE, everything worked fine with 3 APs WAX610 but now there is no PoE anymore. GS316EP is on the newest firmware, I resetted it etc. APs are working fine if they are powered externally but not with PoE. I also ordered a PoE Tester and there is also no power over the cable. I also tested directly at the switch. PoE Settings for the port are standard: IEEE902 802.3at 30 W But the status (same for every port) shows deactivated, 0 V, 0 mA, Status: No Errors, 0 W but Temp 275 C°. Can someone help me out?53Views1like1Comment
