PPPoE needs to be enabled
1 TopicR6900 Nighthawk setup wizard disabled
I used Nighthawk R6900 in the USA for a while. Everything worked fine. Now i am using same router in India for ACT ISP. To configre PPPoE, option 'Internet setup wizard' is disabled. I need this option, to avoid frequent login of ACT ISP protal page. Please suggest ASAP.Solved3KViews0likes3Comments
