Pace 5268
1 TopicIP Passthrough with AT&&& Gigapower Pace 5268 to Netgear AC1900 r7000
AT&T UVERSE gigapower has a recommended way to "pass through" IP using what they describe as "dmz plus". There is frighteningly little one can manipulate on the AT&T Pace device. "The device that you would like to be placed in DMZplus must be connected directly to the gateway and configured to obtain an IP address through DHCP," according to the instructions. There are some bad threads which confuse the basic issue. How should a netgear router be configured for this new IP pass though? The Netgear r7000 has a knowledge base article on dmz which does not even mention IP Pass through. The AT&T Pace 5268 configuires out of the box at 192.168.1.1-254. I set my r7000 to 192.168.10.1-254 to avoid the most obvious conflicts. Should the "Default DMZ server" be checked on the r7000? If so, whose firewall is in effect? The Pace firewall? Thanks in advance.Solved23KViews0likes8Comments
