Power Outage
2 TopicsPower Outage NightHawk 6.0, Now Can't Login to Router
I saw almost the exact problem in forums from 2012 for older Netgear routers - but didn't see a good answer. It won't let me enter the correct model number but this is a new Nighthawk R8000 AC3200with 3 access points and 2.4 and 5.0 Ghz. Had a quick 2 second power outage (I have whole house surge protection), the Nighthawk kept all it's settings and I can connect wirelessly or via RJ45 ehternet - no problems. But I can't log into the web page to change settings etc. My Nighthawk is connected to a Time Warner Arris cable modem which has wireless disabled. I powered the Nighthawk off for 60 seconds and let it come back, but same situation, everything works great but I can't log into the NIghthawk web page. I do see via Netgear-Genie that it just shows everything connected through the Arris modem 192.168.0.1 The Nighthawk was previously accessed on 192.168.1.1 I also see in Network-Genie the Nighthawk seems to be on 54.200.99.0 which just takes me to a Netgear.com site. I know I am connected to one of the Nighthawk's access points, so it is strange that I can't get to the web page either via wireless or ethernet connection. Anyone know what I can do. I hate to re-install the Nighthawk but I will if on one has any other technical guidance. THANKS, RalphSolved4.7KViews0likes2CommentsReadyNAS NV+ Fails to Power Up after Electricity Outage
I have two Ready NAS NV+ boxes and both have experienced failure to restart after electricity outages due to storms and similar situations. The two systems seem to be taking it in turn as to which will not start after these electricity outages (I know that is not at all scientific). Both seem to have come back to life after a few weeks of downtime or after another electricity outage. Any ideas on what is going on here? Or how to make the restart happen sooner? Box 1 (currently powered up) - Firmware 4.1.14, Linux 2.6.17.14 ReadyNAS Box 2 (currently will not power up) - not sure3KViews0likes4Comments
