Powerline 1000
2 TopicsPLW1000 slow internet speeds
I'm getting very slow internet speeds from my Powerline both wifi and Ethernet. Equipment: Netgear AC1750 Wifi Cable Modem Router Xfinity 400mbps internet PNW1000v2 Wifi Speed tests: - 420mbps consistently in the living room via wifi from the AC1750 - 140mbps from the wifi via PNW1000 in the living room. - 78 mbps in my office via AC1750 wifi. - Only 49mbps in my office via the PNW1000, both wifi and ethernet. Tested using iPhone, tablet (Windows 10) and laptop (Windows 10) Verified speeds via Google and Speedtest.net Used wifi analyzer to adjust channels Used multiple outlets in both rooms in testing speed Suggestions? Much appreciated5.8KViews0likes5CommentsUnable to enable WiFi connection with Power 1000
Netgear genie login fails when using the default for router settings. User name: admin Password default: password ISP is Frontier using their modem/WiFi/router. Powerline 1000 connects fine with ethernet cables. There is no firewall according to Frontier. Appreciate any ideas or option to create a WiFi connection. Thanks in advance. SARTRE2KViews0likes5Comments
