R8000 Nighthawk SSID
1 TopicR8000 - Consolidating SSID's
Is there a technical reason having the device configured with 3 seperate SSID's (or 2 is Smart Connect is selected)? I have noticed if I connect to the default NETGEAR20 SSID, the device will end up on another SSID (5G-1 or 5G-2, which is fine, as I assume its intended behaviour), but can I change the SSID to be the same for all WIFI networks? Or alternatively, if the SSID's must be different for whatever technical reason, can the 5G SSID be configured to not advertise? Thanks, AlbertSolved5.4KViews0likes1Comment
