RAW_SPIN_LOCK
1 TopicError: DO_RAW_SPIN_LOCK+C, need to resync...
Hi, I think it's after a reboot... I rebooted my ReadyNAS 104 then went to job, then realised I wasn't able to access it... Came back to home and it's displaying: DO_RAW_SPIN_LOCK+C.... I went so stressed, because I already lost some data with this tons of errors I did in the past. it's running since fresh "format" on x-raid 3x4TB WD Reds... The only things I recently done different, is trying of doing a snapshot of my Thicks LUNs iSCSI... Now it will resync for 3-5 days, then I'll do a backup, I can currently access the shares and the web interface.... Any suggestion on what's bad? I downloaded the log... And don't want to lose my (some new) datas, it's priceless... Thanks!Solved2KViews0likes7Comments
