RJ-45
1 TopicGS724TPv2 1000 BASE-X port options
Hi, new to the community looking for options :) I’ve got the GS724TPv2 PoE+ across 24 ports plus 2 extra 1000 BASE-X empty slots, the extra 2 x 1000 BASE-X empty slots I don’t plan on using and wondering if they can be utilized for a similar purpose to plug to a NAS with patch cables. Online, I find that there are options for 1000 BASE-T transceiver modules in RJ45 to run patch cable to other devices (if possible?). Million dollar question, can the 1000BASE-T SFP Copper RJ-45 Transceiver Module be plugged in a 1000BASE-X slot? I'd like to use them as connections to my ReadyNAS. Thanks, YasSolved1.6KViews0likes2Comments
