RN422
3 TopicsIs PLEX compatibile with ReadyNAS 420 Series
Neither ReadyNas RN422 nor 424 are the PLEX compatibility list. Yet PLEX is listed in the Add-on Applications section of the ReadyNAS 420 Series. If one also consider that RN31X models are on the PLEX compatibility list it looks really strange that the 420 Series is not compatible. Cannot understand if is only a problem of updating the list, or if there is some real issue. Does anyone know if PLEX runs on a RN424?Solved4.2KViews0likes7CommentsUSB Hub for RN422
I have an RN422 running OS 6.7.1 and would like to connect two WD 4TB Passport Ultra hdd's via a USB 3 hub. Also on the hub is an APC XS 1500 UPS connection and a 2GB flash memory stick with my encryption keys. An EDA 500 is also connected to the RN 422. The USB hub is an I/O Crest Superspeed USB 3 4 Port hub.This device has it's own power supply. The issue I'm having is the RN422 will only accept one of the Passport Ultra to be connected at a time USB and that connection gets dropped intermittently or whenever the UPS or flash memory stick is connected to the hub. The connection is not reliable. There is no problem connecting either Passport Ultra directly on the other USB connector on the RN 422, that connection is stable. If in the end I have to connect only one of the Passport Ultra's on the USB hub, I can live with that. But I need a reliable connection on a hub for at least one of the Passport Ultra hdd's. Is there a 4 port USB 3 hub that is recommended for the RN422 and will work with a WD Passport Ultra 4 TB hdd? Thank you your help is appreciated.ReadyNAS 422 and 424
Hi all, At this year's CES, NTGR has introduced five new ReadyNAS products. ReadyNAS 524X and 528X as members of the RN520 Series. ReadyNAS 628X as the highest performance, largest capacity ReadyNAS desktop, completing the RN620 Series. The performance of these machines are amazing. They are positioned as the be-all and end-all performance data storage solution for businesses. In addition, the company unveiled a new class of products, ReadyNAS 400. The first series is ReadyNAS 420, with two models, ReadyNAS 422 and 424. Keeping up with the fine ReadyNAS tradition, the last digit denote the number of bays. The products were featured at Intel's Retail Breakfast forum, as a showcase of Intel's prowess in digital home. Intel chosed NETGEAR as the launch partner for the latest and greatest Atom, AKA, Denverton. There is a picture of the Intel conference, and the VP of Product Management from NETGEAR's Commercial Product Business Unit. https://www.facebook.com/groups/NetgearReadyNAS/ The product is at its final stages of pre-production. You should see them on the shelf by March. Best regards, Doug2.2KViews0likes1Comment
